Accessing physical memory on ARM
Thu Nov 12 06:54:07 UTC 2015
On 12/11/15 07:39, Chris Johns wrote:
> On 12/11/2015 5:26 PM, Sebastian Huber wrote:
>> On 11/11/15 23:32, Adit Sahasrabudhe wrote:
>>> It turns out it’s a cache issue. Our application has the FPGA on the
>>> SoC writing data to the SDRAM. We ran another test where we made sure
>>> the test buffer would create a cache miss and sure enough, the data is
>>> read just fine.
>>> So one last question then, since this data is only written by the
>>> FPGA, it seems like I have two options:
>>>   1. Create a new section in my linker script and configure the MMU for
>>>      that section to not use cache (using startup/mmu_config.c in the BSP)
>> You can use rtems_cache_coherent_allocate() or place global data into
>> non-cacheable memory via the BSP_NOCACHE_SECTION and
>> BSP_NOCACHENOLOAD_SECTION attributes (#include <bsp/linker-symbols.h>).
> Thanks Sebastian.
> Is there a documentation link describing this?
No, we don't have BSP documentation.
>>>   1. Or, I can invalidate the cache whenever we want to read this
>>>      buffer (not too often). Is there an API available to do cache
>>>      invalidations? We tried the inline routines in arm-cp15.h, but it
>>>      causes a fatal exception.
>> Use the rtems_cache_*() routines for this.
> A documentation link?
The cache manager is not documented in the user manual.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
