Beagleboards
Sat Nov 28 12:35:55 UTC 2015
Thanks Mike. If you're interested in sharing what you did or in
documenting the problem, it would be great if you could create an
account on our Trac [1] and open a ticket describing the bug you
encountered.
[1] https://devel.rtems.org/newticket
Gedare
On Fri, Nov 27, 2015 at 11:00 PM, Mike Westfall <mike at mesamike.org> wrote:
> I did figure it out finally.
> As Chris Johns indicated, it turned out to be that the RSB 4.11 branch is
> not requesting the RTEMS Tools
> 4.11 branch.
> I edited one of the .cfg files somewhere to fix that  and now it all works.
> Mike Westfall
> On Fri, Nov 27, 2015 at 12:05 PM, Mike Westfall <mike at mesamike.org> wrote:
>> Even after that fix, the build still fails, eventually yielding this:
>> rtems-syms -e -c "-mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
>> dl-sym.o dl01.pre
>> : error trying to exec 'arm-rtems4.12-gcc': execvp: No such file or
>> directory
>> What? Why is it looking for arm-rtems4.12-gcc??? So far I've been
>> unsuccessful in tracking that down.--
>> Mike Westfall
> users mailing list
> users at rtems.org
