thread allocation blocked by stack size
Martin Werner
martin.werner at aacmicrotec.com
Tue Nov 3 12:40:41 UTC 2015
On Mon, 2015-11-02 at 13:11 -0600, Joel Sherrill wrote:
> On Mon, Nov 2, 2015 at 1:00 PM, Martin Werner
> <martin.werner at aacmicrotec.com> wrote:
> Hi,
> I'm porting a linux application to rtems, and placing a set of
> applications into rtems tasks. These tasks individually create
> a set of
> threads via pthread_create().
> So you have both a Classic API init task and a POSIX init thread?
Yes, at least for now.
On Mon, 2015-11-02 at 14:36 -0500, Gedare Bloom wrote:
> On Mon, Nov 2, 2015 at 2:00 PM, Martin Werner
> > I'm running into issues with stack allocation, in that the second task
> > to start fails to start some of its threads with pthread_create()
> > reporting EAGAIN.
> > I've dug down a bit and seen that this is fundamentally due to
> > cpukit/score/src/threadstackallocate.c:38
> > stack_addr = (*stack_allocate_hook)( the_stack_size );
> What is "the_stack_size"?
For the threads of this application it is set to 65536
> > I've experimented with tweaking task stack size argument in
> > rtems_task_create(...), and modifying the following defines in my
> > initialization:
> > CONFIGURE_EXECUTIVE_RAM_SIZE
> > CONFIGURE_MAXIMUM_TASKS
> > CONFIGURE_MAXIMUM_POSIX_THREADS
> > CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
> > CONFIGURE_MINIMUM_TASK_STACK_SIZE
> What did you set this one to?
I've tested setting it to (10000*1024) (512*1024), (10*1024), (0), and leaving
it unconfigured.
> > * Is there some other way to increase the stack size that I should be
> > using?
> For pthreads you can set the attr->stacksize to request non-default size.
This would change the stack requirement of each thread, right? But I want to
accomodate those requirements, not change them.
On Tue, 2015-11-03 at 09:09 +0100, Sebastian Huber wrote:
> Use only:
> #define CONFIGURE_UNIFIED_WORK_AREAS
> #define CONFIGURE_UNLIMITED_OBJECTS
I have tried doing this, with no visible change in behaviour.
> Build the samples (--enable-tests=samples) and run the ticker.exe on
> Qemu. This must work.
The ticker sample works as expected on my qemu setup.
Thanks
Martin Erik Werner
