Possible bug and lacking feature in BBB bsp, GPIO API hooks
Steve B
sbattazzo at gmail.com
Wed Nov 4 04:18:19 UTC 2015
Attaching my init.c code now (I went through and trimmed out whatever was
irrelevant).
Please give this a run and let me know if you see the same behavior.
Steve
On Mon, Nov 2, 2015 at 9:31 AM, Steve B <sbattazzo at gmail.com> wrote:
> I just looked at some sample code on Ketul's github, and the source code
> of the API itself, rather than any actual documentation.
> I have already made calls to rtems_gpio_initialize() and
> rtems_gpio_request_pin() as Ketul suggested.
> I am about to go on travel but I will attach my code once tonight I get
> settled in, and maybe one of you can run it and see if you agree with me on
> the symptom.
> Steve
> On Sat, Oct 31, 2015 at 6:45 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> This problem indicates a lack of clear documentation. Steve, where did
>> you look for guidance on using the API?
>> On Sat, Oct 31, 2015 at 5:11 AM, Ketul Shah <ketulshah1993 at gmail.com>
>> wrote:
>> > Hi Steve,
>> > I suggest you to kindly configure GPIO API by using following functions
>> in
>> > your code,
>> > rtems_gpio_initialize();
>> > rtems_gpio_request_pin(.....);
>> > After using it should work properly. Me and Ben had tested on our BBBs.
>> > For example code you can have a loot at link.
>> > Hope this helps.
>> > Thanks,
>> > Ketul
>> > On 31 October 2015 at 05:11, Steve B <sbattazzo at gmail.com> wrote:
>> >> Hi again guys,
>> >> I've noticed an unexpected (to me) behavior in the GPIO API for
>> Beaglebone
>> >> Black.
>> >> I borrowed a periodic task from the clock test source, and set it up to
>> >> toggle the GPIOs once every couple seconds.. here's what I have:
>> >> rtems_task Test_task(
>> >> rtems_task_argument task_index
>> >> int task_count = 0;
>> >> rtems_time_of_day time;
>> >> rtems_interval ticks;
>> >> ticks = task_index * 2 * rtems_clock_get_ticks_per_second();
>> >> for ( ; ; ) {
>> >> task_count++;
>> >> (void) rtems_clock_get_tod( &time );
>> >> if ( time.second >= 35 ) {
>> >> puts( "*** END OF CLOCK TICK TEST ***" );
>> >> //exit( 0 );
>> >> while(1);
>> >> put_name( Task_name[ task_index ], FALSE );
>> >> print_time( " - rtems_clock_get_tod - ", &time, "\n" );
>> >> //Toggle GPIO
>> >> if(task_count & 1) {
>> >> rtems_gpio_set(LED1);
>> >> rtems_gpio_set(LED2);
>> >> else rtems_gpio_clear(LED1);
>> >> (void) rtems_task_wake_after( ticks );
>> >> Notice I've defined that if the least significant bit of my variable
>> >> task_count is 1, then I set both LED1 and LED2. If that LSB is zero, I
>> just
>> >> call to clear LED1.
>> >> When I actually run this, both LED1 and LED2 are being cleared! Same is
>> >> true with the 3rd and 4th user LEDs as well, if I happen to set all
>> four of
>> >> them. So I think somehow rtems_gpio_bsp_clear() is clearing the entire
>> bank,
>> >> not just the single pin specified in the argument. Can somebody
>> confirm this
>> >> behavior?
>> >> I will dig around and see if I can figure out why it's happening and
>> >> generate a patch if I find it.
>> >> Also, I was hoping to be able to toggle a GPIO output by checking its
>> >> current state and using that to decide whether to set or clear, but I
>> don't
>> >> see anything in the API that would allow me to check the state of an
>> output.
>> >> Is this a known/intended limitation?
>> >> Cheers,
>> >> Steve
>> >> _______________________________________________
>> >> users mailing list
>> >> users at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/users
>> > users mailing list
>> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20151103/a15bb0b0/attachment-0002.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20151103/a15bb0b0/attachment-0002.bin>
