RTEMS on Zynq Microzed
Davide Viti
zinosat at tiscali.it
Thu Oct 1 15:34:59 UTC 2015
Hi Jeff,
2015-10-01 15:54 GMT+02:00 Webb, Jeffrey A. <jeff.webb at nta-inc.net>:
> That is basically the process I followed, although I used the Xilinx xsdk
> tool. (I did not know about the open source tool -- I will try it when I
> get a chance. Do you still use the Xilinx tools to generate the fsbl, or
> something else?) There seems to be a somewhat long delay when I boot up my
> RTEMS application the first time, and there is some issue with the serial
> port driver that causes missing characters at first. I usually push the
> reset button, and things clear up on subsequent reboots. Anyway, it sounds
> like there may need to be some changes to the bsp for the microzed, or at
> least some configuration parameters. Did you look in the BSP configure
> script for options like clock rates that may need to be changed? I had to
> change the peripheral clock configure option to get the ticker.exe tasks to
> run at the proper rate, although this didn't seems to alter the baud rate
> settings. I might be able to get my hands on a microzed, but it will
> probably be a couple weeks before I
> have time to try that.
> -Jeff
I installed petalinux and did not spend too much time working with it, so
I'm rather unexperienced with most of the things I'm talking about...
Using a freely available tool, I avoided installing the Xilinx SDK and
having to handle licenses and stuff, which I would need only for the
bootgen utility:
I had previously verified that a project compiled with petalinux and a
BOOT.BIN generated with mkbootimage is working properly on the target.
The fsbl.elf file is taken from the images folder of an existing (random)
petalinux project I built in the past.
As for the settings, I assumed it should work out-of the box: in buildroot
nothing had to be changed.
Today I tried to rebuild the BSP switching uart0 with uart1: uboot dts file
defines serial0=&uart1, whereas I noticed that in RTEMS /dev/ttyS0 is
associated to UART_0, /dev/ttyS1 is associated to UART_1. I'm totally new
to rtems so I might have done something utterly wrong.
I notice that with uboot, after loading the bitstream, the blue led lights
up: after running the "bootm" command, nothing comes out of the serial, but
the led stays blue.
whereas, f I run on purpose at the wrong address, so that the board hangs,
the led switches off.
If you have some ideas to test, and the patience to give me a few advices,
I'll be happy to try those.
Thank you
Davide
URL: <http://lists.rtems.org/pipermail/users/attachments/20151001/4f06686c/attachment.html>
