Looking for Advice on Selecting Trace Hardware and Software for RTEMS and Cortex-M
Fri Oct 23 14:17:28 UTC 2015
Hello Isaac,
I didn't use the Lauterbach trace on this platform, but it is quite
useful in general. Lauterbach offers a low cost trace solution for Cortex-M:
http://www.lauterbach.com/frames.html?microtrace.html
They provide RTEMS awareness. Due to the instability of internal kernel
APIs, this usually requires some support from Lauterbach for your
current RTEMS version. This is normally done in a couple of work days.
On 23/10/15 15:57, Isaac Gutekunst wrote:
> Hi All,
> We are considering purchasing trace hardware from Lauterbach as it is
> the only solution we could find that has an independent trace and and
> debug tool i.e. isn't tied into a particular compiler tool chain.
> I have a suspicion that (in theory), any debugger supporting the
> ARMv7m instruction set and the ARM EABI (especially calling
> conventions), should be able to debug and trace any Cortex-M
> processor, regardless of the compiler tool chain used to build the
> file. Is their any truth to this suspicion?
> Does anyone have experience with this or other debug and trace tools
> for Cortex-M that work with RTEMS (or at least GCC and ELF files) and
> a Linux host?
> To clarify what I mean by trace, I am interested support for the ARM
> CoreSight debug architecture including ETM, ITM, ETB, etc that can do
> instruction level trace and display data from the ITM, potentially
> doing interesting things like plotting data.
> Regards,
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
