memory allocation for DMA (how to make bdbuf use non-cacheable region for SD card read and write reuqest)
Wed Sep 2 13:56:11 UTC 2015
On 02/09/15 15:33, Chan Kim wrote:
> My question is :  how come the buffer used for SD card read or write request from the bdbuf is allocated in cacheable memory? I guess there should be setting that tells bdbuf to use some area that the bsp assigned for DMA(non-cacheable). Or , maybe I should map the buffer address to non-cacheable adderss and copyit myself?(should be slow). What is the correct method?
It makes no sense to put the buffers in non-cacheable memory. The
buffers are already cache line aligned, so you can safely use cache
flush/invalidate operations or use a bounce buffer.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
