[PATCH 2/4] qemu.cfg: Options changed to capture test output
Chris Johns
chrisj at rtems.org
Sat Sep 26 07:18:21 UTC 2015
On 29/07/2015 8:58 pm, Sebastian Huber wrote:
> On 29/07/15 12:56, Ric Claus wrote:
>> tester/rtems/testing/qemu.cfg | 3 ++-
>> 1 file changed, 2 insertions(+), 1 deletion(-)
>> diff --git a/tester/rtems/testing/qemu.cfg
>> b/tester/rtems/testing/qemu.cfg
>> index a3310bc..4c5d256 100644
>> --- a/tester/rtems/testing/qemu.cfg
>> +++ b/tester/rtems/testing/qemu.cfg
>> @@ -51,7 +51,8 @@
>> # Qemu common option patterns.
>> -%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> -nographic
>> +#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> -nographic
>> +%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> -nographic
>> %define qemu_opts_no_net -net none
>> # Qemu executable
> In case this file is used for all Qemu based BSPs, then I don't think
> this will work, e.g. it may break the realview_pbx_a9_qemu for example.
This is true and some thing I need to address in the tester. I have
pushed the changed as is.
