Where exactly do system initialization handlers get registered?
Mon Apr 4 05:35:06 UTC 2016
Hello Travis,
there is some documentation in the users manual
https://docs.rtems.org/doc-current/share/rtems/html/c_user/Linker-Sets.html#Linker-Sets
and the ticket
https://devel.rtems.org/ticket/2408
You can get the installed handlers via "nm ticker.exe | grep _Linker |
sort".
You need the FDT to boot the T-series BSP, see README of this BSP. In
case your debugger doesn't work properly, then I would buy a better one
(e.g. Lauterbach), otherwise it will be probably very hard and time
consuming to get it running.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
