How to install a GNAT cross-compiler and toolset?
Jan Sommer soja-lists at aries.uberspace.de
Mon Apr 4 19:57:54 UTC 2016
Am Monday 04 April 2016, 16:57:24 schrieb Thibaud Backenstrass:
> Hello,
> After the build of RTEMS failed with multilib enabled for sparc-leon3 [1],
> I am wondering how to install a GNAT Ada toolset for the SPARC Leon3
> processor. Did somebody managed to do it with RTEMS 4.11, and if yes, how?
Yes, it took some time to figure out how circumvent some of the issues.
You might try to follow the instructions given here:
http://taste.tuxfamily.org/wiki/index.php?title=Building_a_TASTE-y_RTEMS
If you find some missing or incorrect steps, please report them.
Best regards,
   Jan
> My strategy up to now was to try to build RTEMS with multlib enabled since
> gcc doesn't compile (missing the sys/socket.h file) whit
> --enable-language="c,c++,ada". However I was told that this RTEMS options
> was a developer and experimental one, but I cannot figure out that the
> build of the Ada toolset is dependant on it. Can somebody explain me
> precisely how to install the Ada cross compiler?
> References:
> [1] https://lists.rtems.org/pipermail/users/2016-March/030075.html
> Thank you in advance and best regards,
> Thibaud
