Is there any framebuffer testcases?
Peng Fan van.freenix at gmail.com
Tue Apr 5 12:48:00 UTC 2016
Hi Pavel,
On Mon, Apr 04, 2016 at 03:25:06PM +0200, Pavel Pisa wrote:
>Hello Peng Fan,
>On Sunday 03 of April 2016 19:21:19 Joel Sherrill wrote:
>> On Apr 3, 2016 9:17 AM, "Peng Fan" <van.freenix at gmail.com> wrote:
>> > Hi,
>> > I am porting RTEMS to i.MX6UL and trying to enable lcdif now. I wonder is
>> there any simple framebuffer testcases?
>> No. But there should be. This would be a nice submission.
>> > Also in git.rtems.org, I can not find the graphic toolkit. Is the graphic
>> toolkit not being maintained now?
>there is Microwindows build as part of RSB.
>Microwindows contains more test executables.
>It is not minimal or most easy to build as simple
>test probably. We usually used some minimal test
>to draw single line directly from graphic driver.
>We usually use "mdemo" or "malpha" to test
>Microwindows
>For Microwindows build from
>  git://git.rtems.org/rtems-source-builder.git
>I have used for i386 next commands for 4.11
>cd rtems
>../source-builder/sb-set-builder \
>    --log=graphic-build-log.txt \
>    --prefix=/opt/rtems4.11 \
>    --rtems-bsp=i386/pc686 \
>    --with-rtems-bsp=pc686 \
>    --pkg-tar-files \
>    4.11/graphics/graphics-all.bset
>I have used the similar for RPi.
>RSB points to Micowindows from GSoC 2012 still
>but RTEMS support related changes have been
>integrated to Microwindows mainline
>  https://github.com/ghaerr/microwindows
>You do not want to bother with keyboard support for
>initial support. This is disable by
> microwindows-0.93-dev-without-keyboard.diff
>added by Yang Qiao to RSB for his porting
>diff --git a/src/drivers/Objects.rules b/src/drivers/Objects.rules
>--- a/src/drivers/Objects.rules
>+++ b/src/drivers/Objects.rules
>@@ -253,8 +253,8 @@ MW_CORE_OBJS += $(MW_DIR_OBJ)/drivers/kbd_pipe.o
> endif
> ifeq ($(ARCH), RTEMS)
>-MW_CORE_OBJS += $(MW_DIR_OBJ)/drivers/kbd_rtems.o
>-MW_CORE_OBJS += $(MW_DIR_OBJ)/drivers/mou_rtems.o
>+MW_CORE_OBJS += $(MW_DIR_OBJ)/drivers/kbd_null.o
>+MW_CORE_OBJS += $(MW_DIR_OBJ)/drivers/mou_null.o
> endif # RTEMS architecture
> ifeq ($(LIRCKBD2), Y)
>Some pointers to RTEMS graphics related infomations can be found
>in wiki. Some should be moved to archive already and so updated
>as projects move in time
>https://devel.rtems.org/wiki/Projects/GraphicsToolkit
Thanks for you kindly help. I'll try on my i.MX6UL board.
Thanks,
Peng.
>Best wishes,
>             Pavel
