How to install a GNAT cross-compiler and toolset?
Wed Apr 6 05:35:28 UTC 2016
On 5/04/2016 5:57 AM, Jan Sommer wrote:
> Yes, it took some time to figure out how circumvent some of the issues.
> You might try to follow the instructions given here:
> http://taste.tuxfamily.org/wiki/index.php?title=Building_a_TASTE-y_RTEMS
Great page.
> If you find some missing or incorrect steps, please report them.
I wonder if using a separate macro file would be simpler than altering
the RSB configurations file. The --macros option allows you to pass in a
user specific set of RSB macros for this purpose. Have a look at:
https://git.rtems.org/rtems-source-builder/tree/source-builder/config/snapshots/gcc-head.mc
as an example. The snapshots are selected as shown in:
https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gcc-4.7-1.cfg
I see 4.8, 4.9, and 6 do not have these. Maybe:
  # Select Snapshot Macro Maps
  %select gcc-snapshot
  %select newlib-snapshot
  %select mpfr-snapshot
  %select mpc-snapshot
  %select gmp-snapshot
Should be added to gcc-common-1.cfg.
If you run with '--trace --dry-run' the log file will show you the macro
names and you can debug what is happening including how the hashes are
handled.
The nice thing about doing this is the logs and reports that are install
are true to what you have built. You can also provide a specific macro
file for users.
