Loading RTEMS-application with U-boot on Raspberry Pi
Jan Sommer
soja-lists at aries.uberspace.de
Wed Apr 6 22:33:22 UTC 2016
Hello,
I tried (and failed) again to start an RTEMS-application for the raspberry pi using u-boot.
If I start the same binary file directly from the sd-card (i.e. renaming it to kernel.img) it works fine.
In order to test my u-boot I compiled some of the baremetal programs from [1].
There, I can load the binary directly to address 0x8000 and start it with go and I can load the elf-file somewhere into the memory (e.g. 0x100000) and use bootelf to run the program. Both works fine.
However as soon as I try the same mechanisms with a similar RTEMS-application which simply blinks an LED the program never starts.
If I look at the output of readelf for the RTEMS-program [2] I noticed that the entry point address is not 0x8000, but 0x8040.
In comparison the elf-file of the baremetal program [3] has entry point address 0x8000 and under "Flags" it says "has entry point".
I am not very experienced when it comes to linker scripts and elf-format, so I am not sure how to interpret all the different information. Am I on the right track at all here?
Has someone else managed to run RTEMS-applications using u-boot (even on a different platform)?
Best regards,
Jan
[1] https://github.com/dwelch67/raspberrypi
[2] blinker-rtems/o-optimize$ arm-rtems4.12-readelf -e blinker-rtems.exe
ELF Header:
Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
Class: ELF32
Data: 2's complement, little endian
Version: 1 (current)
OS/ABI: UNIX - System V
ABI Version: 0
Type: EXEC (Executable file)
Machine: ARM
Version: 0x1
Entry point address: 0x8040
Start of program headers: 52 (bytes into file)
Start of section headers: 3492848 (bytes into file)
Flags: 0x5000200, Version5 EABI, soft-float ABI
Size of this header: 52 (bytes)
Size of program headers: 32 (bytes)
Number of program headers: 4
Size of section headers: 40 (bytes)
Number of section headers: 34
Section header string table index: 31
Section Headers:
[Nr] Name Type Addr Off Size ES Flg Lk Inf Al
[ 0] NULL 00000000 000000 000000 00 0 0 0
[ 1] .start PROGBITS 00008000 0000b4 000348 00 AX 0 0 4
[ 2] .xbarrier PROGBITS 00000000 010640 000000 00 W 0 0 1
[ 3] .text PROGBITS 00008348 0003fc 00ef88 00 WAX 0 0 4
[ 4] .init PROGBITS 000172d0 00f384 000018 00 AX 0 0 4
[ 5] .fini PROGBITS 000172e8 00f39c 000018 00 AX 0 0 4
[ 6] .robarrier NOBITS 00017300 00f3b4 0e8d00 00 WA 0 0 1
[ 7] .rodata PROGBITS 00100000 00f3c0 000c51 00 A 0 0 4
[ 8] .ARM.exidx ARM_EXIDX 00100c54 010014 000008 00 AL 3 0 4
[ 9] .eh_frame PROGBITS 00100c5c 01001c 000004 00 A 0 0 4
[10] .init_array INIT_ARRAY 00100c60 010020 000004 00 WA 0 0 4
[11] .fini_array FINI_ARRAY 00100c64 010024 000004 00 WA 0 0 4
[12] .jcr PROGBITS 00100c68 010028 000004 00 WA 0 0 4
[13] .rtemsroset PROGBITS 00100c6c 01002c 000038 00 WA 0 0 4
[14] .rwbarrier PROGBITS 00100ca4 010640 000000 00 W 0 0 1
[15] .vector NOBITS 00000000 0000b4 001440 00 WA 0 0 1
[16] .data PROGBITS 00100ca8 010068 0005d8 00 WA 0 0 8
[17] .bss NOBITS 00101280 010640 0018f0 00 WA 0 0 32
[18] .work NOBITS 00102b70 010640 7ef9490 00 WA 0 0 1
[19] .stack PROGBITS 07ffc000 010640 000000 00 W 0 0 1
[20] .nocachenoload PROGBITS 07ffc000 010640 000000 00 W 0 0 1
[21] .comment PROGBITS 00000000 010640 000075 01 MS 0 0 1
[22] .debug_aranges PROGBITS 00000000 0106b8 002cf8 00 0 0 8
[23] .debug_info PROGBITS 00000000 0133b0 27217b 00 0 0 1
[24] .debug_abbrev PROGBITS 00000000 28552b 03004c 00 0 0 1
[25] .debug_line PROGBITS 00000000 2b5577 050cb6 00 0 0 1
[26] .debug_frame PROGBITS 00000000 306230 0051c8 00 0 0 4
[27] .debug_str PROGBITS 00000000 30b3f8 0152f2 01 MS 0 0 1
[28] .debug_loc PROGBITS 00000000 3206ea 020a63 00 0 0 1
[29] .debug_ranges PROGBITS 00000000 34114d 0059e0 00 0 0 1
[30] .ARM.attributes ARM_ATTRIBUTES 00000000 346b2d 000036 00 0 0 1
[31] .shstrtab STRTAB 00000000 354aa8 000148 00 0 0 1
[32] .symtab SYMTAB 00000000 346b64 008ab0 10 33 1649 4
[33] .strtab STRTAB 00000000 34f614 005494 00 0 0 1
Key to Flags:
W (write), A (alloc), X (execute), M (merge), S (strings)
I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown)
O (extra OS processing required) o (OS specific), p (processor specific)
Program Headers:
Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align
EXIDX 0x010014 0x00100c54 0x00100c54 0x00008 0x00008 R 0x4
LOAD 0x0000b4 0x00000000 0x00000000 0x00000 0x01440 RW 0x1
LOAD 0x0000b4 0x00008000 0x00008000 0x0f300 0xf8000 RWE 0x4
LOAD 0x00f3c0 0x00100000 0x00100000 0x01280 0x7efc000 RW 0x20
Section to Segment mapping:
Segment Sections...
00 .ARM.exidx
01 .vector
02 .start .text .init .fini .robarrier
03 .rodata .ARM.exidx .eh_frame .init_array .fini_array .jcr .rtemsroset .data .bss .work
[3] blinker02/plus$ arm-none-eabi-readelf -e blinker02.elf
ELF Header:
Class: ELF32
ABI Version: 0
Machine: ARM
Version: 0x1
Entry point address: 0x8000
Start of section headers: 33424 (bytes into file)
Flags: 0x5000202, has entry point, Version5 EABI, soft-float ABI
Number of program headers: 1
Number of section headers: 7
Section header string table index: 4
Section Headers:
[ 1] .text PROGBITS 00008000 008000 0000bc 00 AX 0 0 4
[ 2] .ARM.attributes ARM_ATTRIBUTES 00000000 0080bc 00002b 00 0 0 1
[ 3] .comment PROGBITS 00000000 0080e7 000038 01 MS 0 0 1
[ 4] .shstrtab STRTAB 00000000 00811f 00003a 00 0 0 1
[ 5] .symtab SYMTAB 00000000 00815c 0000f0 10 6 10 4
[ 6] .strtab STRTAB 00000000 00824c 000043 00 0 0 1
Key to Flags:
Program Headers:
LOAD 0x000000 0x00000000 0x00000000 0x080bc 0x080bc R E 0x10000
Segment Sections...
00 .text
