Is there any framebuffer testcases?
Wed Apr 6 22:57:16 UTC 2016
On 6/04/2016 11:09 PM, Peng Fan wrote:
> The latest rtems-source-builder master branch does not support
> 4.11/graphics/graphics-all.bset.
The 3rd party packages need to be brought over to master.
I wonder if they should be at the rtems/config top level and not under a
specific release. The original layout was done when the repo had all
releases and we are slowly moving away from this.
> I reverted to earlier commit 08aa888205798b3416d24544fd06613fd683bb1e.
> I use rtems 4.12 toolchain.
> Met the following error:
> ../source-builder/sb-set-builder --log=l-g.txt  --prefix=/home/Freenix/development/rtems/4.12 --rtems-bsp=arm/raspberrypi --rtems-version=4.11 --pkg-tar-files 4.11/graphics/graphics-all.bset
> RTEMS Source Builder - Set Builder, 4.12 (08aa88820579)
> warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
> Build Set: 4.11/graphics/graphics-all.bset
> Build Set: 4.11/graphics/libjpeg.bset
> config: graphics/libjpeg-9a-1.cfg
> internal error: pkgconfig failure
I think you are seeing some effects from the conversion to python3 and
python2. There have been fixes.
I suggest getting a copy of the databases, graphics, net-mgmt, and net
build set files from 4.11 and adding to rtems/config and then seeing if
the package builds. Let me know how it goes.
