got error when making arm cross compiler by RSB
Wed Apr 6 23:02:23 UTC 2016
On 7/04/2016 2:20 AM, 2654577874 wrote:
> Hi,
> I got error report when use this command in RSB.my host is ubuntu 12.04,RSB  git branch is  master.
> command is:
>   ../source-builder/sb-set-builder --prefix=/home/w/development/rtems/4.9  4.9/rtems-arm
> error report:
> script: 72: # Default environment set up.
> script: 73: LANG=C
> script: 74: export LANG
> script: 75: unset DISPLAY || :
> script: 76: umask 022
> script: 77: cd "/home/w/development/rtems/rsb/rtems-source-builder/rtems/build/arm-rtems4.9-kernel-4.12 (29819a271950)-1"
> script: 78: echo "=> arm-rtems4.9-kernel-4.12 (29819a271950)-1:"
> script: 79: echo "==> %prep:"
> script: 80: source_dir_rtems="rtems-4.12 (29819a271950)"
> source setup: arm-rtems4.9-kernel-4.12 (29819a271950)-1: source rtems -q -c -n arm-rtems4.9-kernel-4.12 (29819a271950)-1-4.12 (29819a271950)
> making dir: /home/w/development/rtems/rsb/rtems-source-builder/rtems/sources
> download: ftp://ftp.rtems.org/pub/rtems/releases/4.9/4.12 -> sources/rtems-4.12 (29819a271950).tar.bz2
> download: ftp://ftp.rtems.org/pub/rtems/releases/4.9/4.12: error: <urlopen error [Errno -5] No address associated with hostname>
> error: downloading (29819a271950).tar.bz2: all paths have failed, giving up
> it seems that I went a wrong place to get tarball, anyone know how can I fix it ?
This is known issue and I need to fix it but I have not had time.
