Is there any framebuffer testcases?
Thu Apr 14 16:04:12 UTC 2016
On Thu, Apr 14, 2016 at 1:30 AM, Sebastian Huber <
> On 14/04/16 08:23, Chris Johns wrote:
>> On 14/04/2016 16:09, Sebastian Huber wrote:
>>> On 14/04/16 08:04, Chris Johns wrote:
>>>> On 14/04/2016 15:56, Sebastian Huber wrote:
>>>>> In case this is important, then we should add a test case to the RTEMS
>>>>> test suite.
>>>> A test is a good idea.
>>>> How would you write a test which checks all the possible externals
>>>> used in newlib and I suppose gcc, indirectly via the apis or
>>>> explicitly? I am thinking explicitly but how do we collect all the
>>>> symbols and check they have no moved?
>>> It has to work automatically.
>> I keep pressing the button but nothing is happening ... ok I will do it.
>> I think a lot of symbols are missing in this file.
>> I suppose the list is a unique set of all external symbols which do not
>> internally resolve with in the tool set libraries. I suppose I can assume
>> multlib variants all have the same unresolved symbols and can filter
>> duplicates.
>> I still not see how to write a suitable test. All you end up doing is
>> testing the linker works and RTEMS is not missing any symbols. Any idea?
> GCC uses link-time tests to check for operating system features. At least
> for libstdc++ some features are unsupported since some symbols are not
> defined (only declared in header files) during GCC build. Let U be the set
> of all undefined symbols in libc, libm and libgcc. Let D be the set of all
> defined symbols in libc, libm, libgcc. Then U \ D must go into crt0.c.
> Also, these symbols must be defined by librtemscpu or librtemsbsp.
Except that I focused on libc only, this is the general way I got my list
of symbols.
empty main.c
sparc-rtems4.12-gcc -c main.c
sparc-rtems4.12-ld crt0.o --whole-archive libc.a --no-whole-archive main.o
I wondered about the rest of the symbols in lock.h but only those mutex
ones came up
undefined.
Whole archive of libraries under consideration + main + stubs should be the
way to go.
--joel
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160414/b4cb2e7f/attachment.html>
