[PATCH] graphics: clone Microwindows from official Greg Haerr's repository.
Pavel Pisa ppisa4lists at pikron.com
Sat Apr 16 13:47:55 UTC 2016
graphics/nxlib is removed from build set because for actual Microwindows
the NXlib is included in Microwindows sources (src/nxlib).
The original NXlib libX11.a is replaced by two varinats
  libPX11 links X11 server replacement directly to the application.
  libNX11 is more X11 concept compatible, application and server
          runs in the separate processes.
 rtems/config/graphics/graphics-all.bset           | 2 +-
 rtems/config/graphics/microwindows-0.93-dev-1.cfg | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/graphics/graphics-all.bset b/rtems/config/graphics/graphics-all.bset
index 5f94184..5527ca3 100644
--- a/rtems/config/graphics/graphics-all.bset
+++ b/rtems/config/graphics/graphics-all.bset
@@ -6,4 +6,4 @@ graphics/libjpeg
 graphics/libpng
 graphics/libtiff
 graphics/t1lib
-graphics/nxlib
+graphics/microwindows.bset
diff --git a/rtems/config/graphics/microwindows-0.93-dev-1.cfg b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
index 7050fdb..0ab9da4 100644
--- a/rtems/config/graphics/microwindows-0.93-dev-1.cfg
+++ b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
@@ -15,7 +15,7 @@
 %define rtems_git_tools_4_11 %{rtems_http_git}/rtems-tools/plain/tools/4.11
-%source set microwindows git://github.com/alex-sever-h/microwin.git
+%source set microwindows git://github.com/ghaerr/microwindows.git
 %patch add microwindows %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev.diff
 %hash md5 microwindows-0.93-dev.diff 5b06e77d9ee42c8ff0032bba07d01c1a
 %patch add microwindows %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev-without-keyboard.diff
1.9.1
