Is there any framebuffer testcases?
Peng Fan van.freenix at gmail.com
Tue Apr 19 09:21:47 UTC 2016
Hi Gedare,
2016-04-16 20:37 GMT+08:00 Gedare Bloom <gedare at rtems.org>:
> On Thu, Apr 14, 2016 at 8:23 AM, Peng Fan <van.freenix at gmail.com> wrote:
> > Actually I just want to a simple test to verify my lcdif driver. Finally
> I
> > would like to use Qt embedded, but I have no idea how much work need to
> be
> > done. The first I can forseen is there is also license issue, libdl may
> > help.
> Peng,
> You may like to browse through the following mailing list thread in
> case you have not seen it before:
> https://lists.rtems.org/pipermail/users/2015-July/029167.html
Thanks. Maybe microwindows is more easier to be enabled on my platform.
Will first try microwindows. Then switch to use QT.
Thanks,
Peng.
> Gedare
URL: <http://lists.rtems.org/pipermail/users/attachments/20160419/41be3cfe/attachment-0001.html>
