RTEMS Linker
printk opentkernel at 163.com
Wed Apr 27 04:33:49 UTC 2016
On Mon, Apr 25, 2016 at 11:57:04AM +0200, Sw-Hw Eng wrote:
> Hello,
Hi, I am new to RTEMS, allow try to answer this question,
please correct me if i am wrong. :D
> I'm working on RTEMS on xilinx zynq.
> The rtems apps included in test suites have as entry point address
> 0x104040. I'm wondering if I can't change that.
> I checked the linkcmds.in but I'm not sure how can I change the entry
> address and the RAM size.
> Can you please tell how can I do that ?
there is a file:
  rtems/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq.inc
include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU = arm
CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
CFLAGS_OPTIMIZE_V ?= -O2 -g
CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
LDFLAGS = -Wl,--gc-sections
How about add a option -T0x00104040
LDFLAGS = -Wl,--gc-sections,-T0x00104040
this will link your image at 0x00104040, and you have to place
your entry point(maybe _start) at the beginning of the text.
this is a note from GNU ld manual:
3.4.1 Setting the Entry Point
The first instruction to execute in a program is called the entry point. You can use the
ENTRY linker script command to set the entry point. The argument is a symbol name:
ENTRY(symbol)
There are several ways to set the entry point. The linker will set the entry point by trying
each of the following methods in order, and stopping when one of them succeeds:
• the ‘-e’ entry command-line option;
• the ENTRY(symbol) command in a linker script;
• the value of the symbol start, if defined;
• the address of the first byte of the ‘.text’ section, if present;
• The address 0.
> Thank you in advance
> Damiens
> users mailing list
> users at rtems.org
duhuanpeng.
