GSoC 2016 Project: RTEMS Port to ARM Cortex-M4F Core-Based MCUs
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Fri Apr 29 17:08:13 UTC 2016
Hi Karel,
Many thanks for your response and for pointing me to these pages.
I was wondering if it is a good idea to rename the LM4F BSPs to TM4C since
TI as replaced these processors with it. This will allow users to easily
identify this BSPs for their use.
Best regards,
Habeeb
On Fri, Apr 29, 2016 at 11:45 AM, Karel Gardas <karel.gardas at centrum.cz>
wrote:
> Hi Habeeb,
> both ARM Cortex-M4F and Tiva TM4C-123x are supported, please have a look
> into https://devel.rtems.org/wiki/TBR/BSP/LM4F120 -- the wiki formating
> is broken since this is a result of mediawiki -> trac conversion probably.
> Anyway, IIRC, what's missing is support for newer TM4C-129x CPUs. I guess
> this may be one of your first steps especially if you like to get ethernet
> working, which is IIRC available only on this cpu family.
> Hmm, wiki does not list it, but the BSP interesting to you is lm3s69xx and
> you can find it in c/src/lib/libbsp/arm/lm3s69xx inside the RTEMS source
> tree: https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx
> Have fun!
> Karel
> On 04/29/16 05:16 PM, Olufowobi, Habeeb wrote:
>> Greetings,
>> I am Habeeb Olufowobi, a graduate student of Systems and Computer
>> Science at Howard University, Washington, D.C. My research focus is
>> embedded systems security with a concentration on Internet of Things
>> (IoT) devices.
>> I will be working on porting RTEMS to ARM Cortex-M4F microcontroller (TI
>> TM4C series Crypto Connected Launchpad) and will like to extend my
>> gratitude to RTEMS community for all the support and also for accepting
>> my project proposal.
>> The main objective of my project is to add processor support and a board
>> support package (BSP) for the TI TM4C LaunchPad MCU. In addition, I will
>> be adding an ethernet driver and lwIP for networking. I will also add
>> console and clock ticks support for the BSP.
>> Thank you.
>> Best regards,
>> Habeeb
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160429/3ef639b8/attachment-0001.html>
