Is there any framebuffer testcases?
Peng Fan van.freenix at gmail.com
Wed Apr 13 10:33:07 UTC 2016
Ok. I see it. It was finally archived in to libscore.a. Please kindly guide
me to fix this, I do not know where to begin.
Thanks,
Peng.
2016-04-13 16:58 GMT+08:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 13/04/16 10:44, Peng Fan wrote:
>> I saw this patch added _Mutex_recusive_Acquire and applied to newlib.
>> https://sourceware.org/ml/newlib/2015/msg00583.html
>> In this patch, i did not see the function definiton. Is it the reason
>> that cause `undefined reference`? If need to implement
>> `_Mutex_recursive_Release`, should make it in rtems code base or newlib
>> code base? I have no clear idea on this.
> It is defined here:
> https://git.rtems.org/rtems/tree/cpukit/score/src/mutex.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/fa5d3832/attachment-0002.html>
