The periodicity of scheduling
Mon Aug 1 13:58:38 UTC 2016
Hello Kuan-Hsun,
it would be interesting to know the behaviour of the Linux EDF scheduler
in this case.
On 01/08/16 15:49, Kuan Hsun Chen wrote:
> Hello All,
> I have used rate_monotonic function series to do some cycle-accuracy
> emulation quite a long time. I believe that some missing features of
> scheduling are essentially required. As I'm not aware of any
> discussion about this before, please correct me if I misunderstand.
> If I understand correctly, the current implementation of
> rtems_rate_monotonic_period() is explicitly assumed the implicit
> deadline or constraint deadline model that the task deadline is always
> less than or equal to the period deadline. If
> rtems_rate_monotonic_period() is called, it is the moment that either
> the task is finished on time or earlier than its period (or inactivate
> as the first call). If a task misses its period, the watchdog will
> mark the period as RATE_MONOTONIC_EXPIRED and update the deadline of
> watchdog.
> However, the behavior is not correct currently. From my point of view,
> the periodic task should always release its workload on time, even it
> misses its deadline. If there are already two expired periods, the
> task should have two more remaining instances workload to execute.
> Especially if the task has arbitrary deadline or even the task is a
> soft real time task, this feature should behave correctly.
> (Soft Real Time task: If a task misses its deadline, it is still
> valuable to gather its result no matter when. If the utilization of
> uniprocessor is not 100%, the tardiness is proved to be bounded.)
> Here I aim at a case that the task misses its deadline with the
> current implementation.
> If a task period is time out (marked as RATE_MONOTONIC_EXPIRED), by
> referring to _Rate_monotonic_Block_while_expired(), the next call of
> rtems_rate_monotonic_period() will only release *one* following
> instance and manipulate the task period with *the calling moment + the
> next length of period*. However, this way of scheduling is in fact
> changing the behaviour of a periodic task:
>  1. There may be more than one instances which are postponed due to
>     the preemption of higher priority tasks. Trivially release only
>     one instance is not correct in the sense of scheduling.
>  2. The period of expired task is shifted and unpredictable. This
>     should be calculated correctly and rapidly by taking the time
>     point of first period released. The deadline of watchdog in this
>     case should be assigned with an absolute tick.
> I have enhanced this feature in the system by adding three additional
> counters in Rate_monotonic_Control structure and one more function to
> do the correct assignment of deadline and job release. I also prepare
> a heuristic example to demonstrate the results. I'm going to fix the
> case for arbitrary deadline later on.
> Please let me know if this feature is sound and essential. I can patch it.
> Best Regards,
> Kuan-Hsun
> M.Sc. Kuan-Hsun Chen
> TU Dortmund
> Department of Computer Science 12
> Design Automation of Embedded Systems
> Otto-Hahn-Strasse 16, Room 102
> 44227 Dortmund
> Germany
> Phone: _+49 231 755 6124_
> Mail: kuan-hsun.chen at tu-dortmund.de <mailto:kuan-hsun.chen at tu-dortmund.de>
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
