call to malloc causing an endless loop in _Heap_Allocate_aligned_with_boundary
Thu Aug 4 04:55:44 UTC 2016
On 03/08/16 21:53, Philippe O'Reilly wrote:
> Hi,
> I am developing an application using RTEMS 4.10. My development
> environment is a Windows PC, with MinGW installed on it. I compile
> RTEMS and my application using gcc version 4.8.1. When I run my
> application, the first printf() executed within a RTEMS task goes into
> an infinite loop. The infinite loop is located in function
> _Heap_Allocate_aligned_with_boundary.
> I isolated the problem by back tracing the code with GDB. Here is the
> callback trace in GDB when I am stuck in an endless loop, with
> information on variables *block* and *heap*:
> */(gdb) where/*
> */#0 _Heap_Allocate_aligned_with_boundary (heap=0x40393410,
> alloc_size=128, alignment=0, boundary=0) at
> c:/opt/rtems-4.10-mingw/src/rtems-4.10/cpukit/score/src/heapallocate.c:186/*
> */#1 0x40049684 in _Protected_heap_Allocate_aligned_with_boundary
> (heap=0x40393410, size=128, alignment=0, boundary=0) at
> c:/opt/rtems-4.10-mingw/src/rtems-4.10/cpukit/score/src/pheapallocate.c:37/*
> */#2 0x4003b254 in malloc (size=128) at
> ../../cpukit/../../../leon3/lib/include/rtems/score/protectedheap.h:98/*
> */#3 0x40025a48 in __smakebuf_r (ptr=0x40d465d0, fp=0x40d46924) at
> ../../../../../../../../gcc/newlib/libc/stdio/makebuf.c:95/*
> */#4 0x40023450 in __swsetup_r (ptr=0x40d465d0, fp=0x40d46924) at
> ../../../../../../../../gcc/newlib/libc/stdio/wsetup.c:67/*
> */#5 0x4002552c in __sfvwrite_r (ptr=0x40d465d0, fp=0x40d46924,
> uio=0x40d4638c) at
> ../../../../../../../../gcc/newlib/libc/stdio/fvwrite.c:63/*
> */#6 0x4001b6a8 in _puts_r (ptr=0x40d465d0, s=0x400bd5b0 "RxTask") at
> ../../../../../../../../gcc/newlib/libc/stdio/puts.c:94/*
> */#7 0x4001b6d8 in puts (s=0x400bd5b0 "RxTask") at
> ../../../../../../../../gcc/newlib/libc/stdio/puts.c:103/*
> */#8 0x400133a4 in tblHandler_RxTask (unused=0) at
> HighLevelControl/src/TableHandler.c:664/*
> */#9 0x400a496c in _Thread_Handler () at
> c:/opt/rtems-4.10-mingw/src/rtems-4.10/cpukit/score/src/threadhandler.c:146/*
> */#10 0x400a486c in _Thread_Handler () at
> c:/opt/rtems-4.10-mingw/src/rtems-4.10/cpukit/score/src/threadhandler.c:88/*//
> */(gdb) print  *block/*
> */$11 = {prev_size = 0, size_and_flag = 0, next = 0x0, prev = 0x0}/*
> */(gdb) print  heap/*
> */$12 = (Heap_Control *) 0x40393410/*
> There seems to be a problem with the pointer to the heap, since the
> content of the first block of the heap is all zeros.
> Does anyone came across the same problem and have a solution for it?
You have probably a heap corruption, e.g. use after free or out of
bounds write access. In case you always end up with the same corrupt
heap block, then you can set a write break point, e.g.
watch ((Heap_Block *) addr)->prev_size)
In RTEMS 4.11 and 4.12 a simple heap protection is enabled via
RTEMS_DEBUG which helps to find common heap corruption problems.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
