Failure in building RSB
xuelin.tian at qkmtech.com
Wed Aug 10 03:38:35 UTC 2016
I didn't save the output.
The host is Ubuntu, and the version of RSB I downloaded from github a few days ago is 4.11 release.
Firstly, I run "sb-check" to check my environment, everything is OK. And then, I entered the rtems file to run "../source-builder/sb-set-build --prefix=...... 4.11/rtems-arm" as usual. It started to download gcc, gdb ... package, and built them. At last, it needed to download rtems-tools from git, then the error came up.
"config: tools/rtems-tools-4.11-1.cfg
git: clone: git://git.rtems.org/rtems-tools.git -> sources/git/rtems-tools.git
error: git command failed (/usr/bin/git): 128
Build FAILED"
Best wishes,
Tim Tian
Date: 2016-08-10 11:18
To: users
Subject: Re: Failure in building RSB
On 10/08/2016 12:37, xuelin.tian at qkmtech.com wrote:
> An error came up when I building RSB. It says that "error: git command
> failed (/usr/bin/git): 128". I checked that command, it should be "git
> clone git..." instead of "git: clone: git...". So, where is the script?
> how can I alter this?
What host?
Which version of the RSB?
What command line did you enter?
Please cut and paste the actual output.
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160810/30dbfe5a/attachment.html>
