Failure in building RSB
xuelin.tian at qkmtech.com
Wed Aug 10 04:00:41 UTC 2016
The original command "git: clone: git://git.rtems.org/rtems-tools.git" didn't work as I tried a couple of times. But the command "git clone git://git.rtems.org/rtems-tools.git" worked fine. So, I want to alter the script, replace the original command with the command "git clone git://git.rtems.org/rtems-tools.git" to see whether it works. So, I need to know where to start.
Best wishes,
Tim Tian
Date: 2016-08-10 11:42
To: xuelin.tian at qkmtech.com; users at rtems.org
Subject: Re: Failure in building RSB
On 10/08/2016 13:38, xuelin.tian at qkmtech.com wrote:
> I didn't save the output.
> The host is Ubuntu, and the version of RSB I downloaded from github a
> few days ago is 4.11 release.
> Firstly, I run "sb-check" to check my environment, everything is OK. And
> then, I entered the rtems file to run "../source-builder/sb-set-build
> --prefix=...... 4.11/rtems-arm" as usual. It started to download gcc,
> gdb ... package, and built them.
Great, this is a good start.
> At last, it needed to download
> rtems-tools from git, then the error came up.
> "config: tools/rtems-tools-4.11-1.cfg
> git: clone: git://git.rtems.org/rtems-tools.git ->
> sources/git/rtems-tools.git
> error: git command failed (/usr/bin/git): 128
> Build FAILED"
Can you clone this repo by hand at the command line?
URL: <http://lists.rtems.org/pipermail/users/attachments/20160810/135c9ddb/attachment.html>
