Zynq Interrupts
Badr El Hiouel
elh.badr at gmail.com
Wed Aug 10 14:41:30 UTC 2016
Hello,
In my RTEMS app, I want to connect a function which is called when a
hardware interrupt occurs. I looked for that in the RTEMS's cpukit and I
found the function rtems_interrupt_handler_install. I used it like this
rtems_status_code installstatus = rtems_interrupt_handler_install(31,
"PL_IRQ",RTEMS_INTERRUPT_UNIQUE,(rtems_interrupt_handler) my_handler, NULL)
The handler I created for this is (it basically clears the interrupt) :
rtems_isr my_handler(void *arg)
volatile unsigned long c= 0;
BASE_IRQ = c;
printf("interrupt cleared \n");
return;
Please tell me if this function and the handler can be used like I did ?
And what is the difference with rtems_interrupt_catch function ? It's a
little bit confusing.
Thank you
________
*Badr EL HIOUEL*
URL: <http://lists.rtems.org/pipermail/users/attachments/20160810/d7a1fc97/attachment.html>
