How to compile testsuites in RTEMS main tree
xuelin.tian at qkmtech.com
Fri Aug 12 08:08:07 UTC 2016
Dear all,
I want to compile the testsuites in "rtems/testsuites/libtests" for example, however, I don't find any Makefile in it. The right way to do is to use the "configure" command to build the samples, am I correct? Here comes the question, is it the same way to run "configure" as building RTEMS, like, "./configure --prefix=... --rtems-bsp=..."?
Best wishes,
Tim Tian
URL: <http://lists.rtems.org/pipermail/users/attachments/20160812/7db1521f/attachment.html>
