How to compile testsuites in RTEMS main tree
xuelin.tian at qkmtech.com
Fri Aug 12 08:22:01 UTC 2016
OK, thanks a lot. I am working on it.
Best wishes,
Tim Tian
Date: 2016-08-12 16:21
To: xuelin.tian at qkmtech.com; users at rtems.org
Subject: Re: How to compile testsuites in RTEMS main tree
On 12/08/16 10:14, xuelin.tian at qkmtech.com wrote:
> I added this command "--enable-tests=sample" when I built the RTEMS
> kernel. But I didn't find anything, or any executables in my
> installation point.
Use "--enable-tests" to build all tests and not just the samples. The
should be in your build tree after the make.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20160812/c9a0893f/attachment.html>
