undefined reference to `main' when trying to build via OMK
Saeed Ehteshamifar
salpha.2004 at gmail.com
Wed Aug 17 19:47:31 UTC 2016
I had no main(). I was using Init() for C++ and C version as well.
On Wed, Aug 17, 2016 at 9:04 PM, Joel Sherrill <joel at rtems.org> wrote:
> Your main() was likely a C++ symbol and the default dummy
> configuration expects it to be a C symbol.
> Anyone have any idea how to be more flexible on this point?
> On Wed, Aug 17, 2016 at 1:07 PM, Saeed Ehteshamifar <salpha.2004 at gmail.com
> > wrote:
>> I ported my app to C and it worked.
>> On Wed, Aug 17, 2016 at 5:03 PM, Joel Sherrill <joel at rtems.org> wrote:
>>> The main() unresolved issue is that for some reason the application is
>>> pulling
>>> in the default configuration in cpukit/libmisc/dummy.
>>> This can be because the application doesn't have its own configuration
>>> defined
>>> or because it has a partial configuration and is missing something like
>>> say
>>> some network or filesystem configuration.
>>> On Wed, Aug 17, 2016 at 8:23 AM, Pavel Pisa <ppisa4lists at pikron.com>
>>> wrote:
>>>> Hello Saeed,
>>>> On Wednesday 17 of August 2016 11:24:12 Saeed Ehteshamifar wrote:
>>>> > Hello,
>>>> > I have a CPP RTEMS app that builds fine with the RTEMS Makefile but
>>>> when I
>>>> > try to build it via OMK, I get the following output:
>>>> we I have not used OMK with C++ on RTEMS. So it is quite possible
>>>> that there is some rule missing. I look at that but for integration
>>>> into RTEMS ecosystem, you should probably try WAF or other
>>>> RTEMS maintainers preferred system.
>>>> Best wishes,
>>>> Pavel
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160817/09598b33/attachment.html>
