Signal manager
groups at chichak.ca
Fri Aug 19 14:15:56 UTC 2016
Strangely, I got my first EXTI interrupt working two days ago.
Mine was on pin PB14 and goes low when active. Cube generated a bunch of code:
first, a file called mxconstants.h with:
#define SOL2ST_Pin GPIO_PIN_14
#define SOL2ST_GPIO_Port GPIOB
and in gpio.c:
/*Configure GPIO pin : PtPin */
GPIO_InitStruct.Pin = SOL2ST_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(SOL2ST_GPIO_Port, &GPIO_InitStruct);
in stm32f4xx_it.c:
* @brief This function handles EXTI line[15:10] interrupts.
void EXTI15_10_IRQHandler(void)
/* USER CODE BEGIN EXTI15_10_IRQn 0 */
/* USER CODE END EXTI15_10_IRQn 0 */
HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_14);
/* USER CODE BEGIN EXTI15_10_IRQn 1 */
/* USER CODE END EXTI15_10_IRQn 1 */
For my code, I hook it using:
status = rtems_interrupt_handler_install(EXTI15_10_IRQn, "EXTI", RTEMS_INTERRUPT_UNIQUE,
(rtems_interrupt_handler) EXTI15_10_IRQHandler, NULL);
if (status != RTEMS_SUCCESSFUL) {
printk(“EXTI interrupt install bombed with %d\n”, status);
And catch the interrupt using:
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) {
if (GPIO_Pin == SOL2ST_Pin) {
I hope this helps.
Andrei from The Great White North
(embedded.fm/blog <http://embedded.fm/blog>)
> On 2016-August-19, at 07:52, Ярослав Лещинский <midniwalker at gmail.com <mailto:midniwalker at gmail.com>> wrote:
> Hi, everyone!
> My battle with stm32 interrupts continues. Three month ago Andrei from The Great White North gave me some code advise:
> In my code I use interrupts for DMA with ADCs, and CAN using the HAL interrupt handler callback structure.
> In this case, DMA2_Stream2_IRQHandler calls HAL_DMA_IRQHandler in stm32f4xx_hal_dma.c which figures what caused the interrupt and calls the appropriate callback.
> In my ADC code I use this:
> rtems_status_code status;
> const char ADC1handlerName[] = "AD1r";
> status = rtems_interrupt_handler_install((rtems_vector_number) DMA2_Stream2_IRQn,
> ADC2handlerName, RTEMS_INTERRUPT_UNIQUE,
> (rtems_interrupt_handler) DMA2_Stream2_IRQHandler, NULL);
> printk("interrupt handler install 2 failed with %d\n", status);
> Later, I have the interrupt callbacks:
> void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc) {
> status = rtems_event_send(ADCTaskId, RTEMS_EVENT_0);
> printk("complete callback failed with %d", status);
> void HAL_ADC_ConvHalfCpltCallback(ADC_HandleTypeDef* hadc) {
> status = rtems_event_send(ADCTaskId, RTEMS_EVENT_1);
> printk("half complete callback failed with %d", status);
> i was trying the same but only for EXTI driver and no result. I have such code:
> http://pastebin.com/BZBNPRbg <http://pastebin.com/BZBNPRbg>
> After flashing, i received in console string "53", when i pushed the button - all stopped, only reset can brought him back to life.
> In C user guide i didn't find any references to rtems_interrupt_handler_install, some info was about rtems_interrupt_catch, but when i try to use this, i received "undefined reference".
> Maybe, someone can help me with that problem?
> Thanks.
> P.S. Sorry for my english.
> 2016-05-17 8:40 GMT+03:00 Ярослав Лещинский <midniwalker at gmail.com <mailto:midniwalker at gmail.com>>:
> Andrei, thanks!
> 17 мая 2016 г. 8:31 пользователь <groups at chichak.ca <mailto:groups at chichak.ca>> написал:
>> On 2016-May-16, at 11:10, Ярослав Лещинский <midniwalker at gmail.com <mailto:midniwalker at gmail.com>> wrote:
>> Hello. I'm try to use rtems with my stm board(stm32f4xx). And for now i have one problem: it's about ISR. The thing is, i have my own drivers, which uses isr(exti driver, uart and etc). I read rtems c-user manual properly, but still can't understand clearly, how i can bring control to rtems signal manager via ASR. I'll be appreciated, if someone can give some advise.
>> Yaroslavl.
> In my CAN code I use:
> status = rtems_interrupt_handler_install(CAN1_RX0_IRQn, "CANR", RTEMS_INTERRUPT_UNIQUE,
> (rtems_interrupt_handler) CAN1_RX0_IRQHandler, NULL);
> printk("Pressure task interrupt install bombed with %d\n", status);
> and use the two call back functions HAL_CAN_RxCpltCallback and HAL_CAN_ErrorCallback in the same way as the ADC callbacks.
> The symbol for external interrupt looks like EXTI0_IRQn and the UART would be like USART2_IRQn.
> Andrei from The Great White North.
> С уважением, Лещинский Ярослав.
> +79814031224
URL: <http://lists.rtems.org/pipermail/users/attachments/20160819/ef96e105/attachment-0001.html>
