Build in msys2 shell fails
Gene Smith gds at chartertn.net
Sat Aug 20 00:47:38 UTC 2016
Installed msys2 on window 10 as recommended. The various "pacman" steps
were not quite as straight forward as described on the msys2 website.
However, I think I got it installed OK and it runs and all packages are
up to date (including the additional packages required by RSB). Also
installed the windows version of python2.
However, when I run (in MSYS shell) a build with the same command line
as on cygwin or linux but with the added options --without-python and
--jobs=none, I immediately see this:
error: failed to load Windows host support
This is coming from builder file .../sb/options.py and indicates that it
thinks the "os.name" is "nt".
I tried installing and using python3 and see the same thing.
Also, running a MINGW64 shell does the same thing with both python
versions. (No path entries to cygwin code are present.)
Am I doing something wrong? (Haven't tried the msys python package which
the documentation says doesn't work with RSB.)
-gene
