Hello World example from example-v2 not working with QEMU
Sambeet Panigrahi
sambeet161616 at gmail.com
Mon Aug 22 09:45:34 UTC 2016
Sir,
I made and bult the image using the instructions from
https://devel.rtems.org/wiki/Building/Grub. I made a hard disk image and
ran the ticker example as given in the instructions for GRUB2. This process
has worked with all the test suite examples but somehow examples-v2 are
giving problems.
On Mon, Aug 22, 2016 at 1:05 AM, Joel Sherrill <joel at rtems.org> wrote:
> Did you see my previous reply?
> On Aug 21, 2016 2:29 PM, "Sambeet Panigrahi" <sambeet161616 at gmail.com>
> wrote:
>> Hi,
>> I followed the https://devel.rtems.org/wiki/Developer/Simulators/QEMU
>> simulate RTEMS for i386. I used the hello world example from examples-v2
>> repository. The source code is directly taken from RTEMS C user guide.
>> * Classic API Hello World
>> #include <rtems.h> //Contains the RTEMS datatypes
>> #include <stdlib.h>//Standard C library
>> #include <stdio.h>//Standard C input ouput library
>> rtems_task Init(
>> rtems_task_argument ignored
>> printf( "\n\n*** MODIFIED HELLO WORLD TEST ***\n" );
>> printf( "Hello Sambeet!How are You?\n" );
>> printf( "*** END OF MODIFIED HELLO WORLD TEST ***\n" );
>> exit( 0 );
>> /* configuration information */
>> #include <bsp.h>
>> /* NOTICE: the clock driver is explicitly disabled */
>> #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_MAXIMUM_TASKS 1
>> #define CONFIGURE_INIT
>> #include <rtems/confdefs.h>
>> /* end of file */
>> I compiled it using RTEMS GCC, the exact same commands as the makefile
>> i.e.
>> /home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/bin/i386-rtems4.11-gcc
>> --pipe -B/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/i386-rtems4.11/pc486/lib/
>> -specs bsp_specs -qrtems -Wall -O2 -g -mtune=i486 -o
>> o-optimize/test.exe test.c
>> that was because makefile was showing some errors
>> sambeet at Holmes ~/Documents/GitRepos/examples/
>> examples-v2/hello/hello_world_c $ make
>> i386-rtems4.11-gcc --pipe -B/home/sambeet/NewRockPort/x8
>> 6/Install/rtems/4.11.0-rc3/i386-rtems4.11/pc486/lib/ -specs bsp_specs
>> -qrtems -Wall -O2 -g -mtune=i486 -c -o o-optimize/test.o
>> test.c
>> /bin/bash: i386-rtems4.11-gcc: command not found
>> make: *** [o-optimize/test.o] Error 127
>> Now I generated the executable successfully but when I run it in QEMU.I
>> get a blank screen.However when I try this which comes with i386
>> testsuites, I get the output
>> * COPYRIGHT (c) 1989-2012.
>> * On-Line Applications Research Corporation (OAR).
>> * The license and distribution terms for this file may be
>> * found in the file LICENSE in this distribution or at
>> * http://www.rtems.org/license/LICENSE.
>> #ifdef HAVE_CONFIG_H
>> #include "config.h"
>> #endif
>> #include <rtems/test.h>
>> #include <bsp.h> /* for device driver prototypes */
>> #include <stdio.h>
>> #include <stdlib.h>
>> /* forward declarations to avoid warnings */
>> rtems_task Init(rtems_task_argument argument);
>> const char rtems_test_name[] = "HELLO WORLD";
>> rtems_task Init(
>> rtems_test_begin();
>> printf( "Hello World\n" );
>> rtems_test_end();
>> exit( 0 );
>> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> QEMU doesn't show any error, just the blank screen, so I am not able to
>> figure out what,s wrong with my code,can somebody help?
URL: <http://lists.rtems.org/pipermail/users/attachments/20160822/084806d1/attachment.html>
