Combining multiple object files into one at link-time
Saeed Ehteshamifar salpha.2004 at gmail.com
Wed Aug 24 14:44:25 UTC 2016
Hello,
In Linux, one can make a shared library that has the binary code for
several objects like this:
gcc -shared -fpic obj1.o obj2.o -o obj.so
Is it possible to do the same with RTEMS objects?
The problem is that I have two separate source files, where one (the test
case) uses the other one (the test setting). I want to dynamically load
*one* object file that contains the binary code for both files.
PS: I tried -shared and -fpic with proper RTEMS C flags, but I also needed
to link my Init task's object file in order to create the shared object
file, which is what I don't want (causes a failure on dlopen).
Best Regards,
Saeed
URL: <http://lists.rtems.org/pipermail/users/attachments/20160824/6fe5f5a7/attachment.html>
