Build of example fails with waf
Gene Smith gds at chartertn.net
Thu Aug 25 06:42:03 UTC 2016
On 08/25/2016 02:01 AM, Chris Johns wrote:
> On 25/08/2016 3:51 PM, Gene Smith wrote:
>> Please ignore more first post!
> Will do :)
>> I realized I needed to run "waf configure ..." from the top level of
>> examples-v2/ but first have to
>> git submodule init
>> git submodule update
>> which puts stuff into the examples-v2/rtems-waf directory.
> Great.
>> Now when I run the configure I see:
>> [gene at hplt examples-v2]$ waf configure
>> --rtems=/home/gene/rtems/install/4.12/bsps
>> --rtems-tools=/home/gene/rtems/install/4.12/tools/
>> --rtems-bsps=arm/stm32f4 --rtems-archs=arm
>> Setting top to                           : /home/gene/rtems/examples-v2
>> Setting out to                           :
>> /home/gene/rtems/examples-v2/build
>> Could not find any architectures
>> (complete log in /home/gene/rtems/examples-v2/build/config.log)
>> Searching for this error, all I see is that "tools without a version are
>> not supported". I built and installed the tools with RSB and they seems
>> to be present and have a version, e.g., under the --rtems-tools there
>> are files like:
>> bin/arm-rtems4.12-gcc-6.1.1
>> bin/arm-rtmes4.12-gcc
>> etc.
> What happens if you remove --rtems-archs=arm from the configure command
> line and just specify the BSP? The BSP name includes the arch.
Same result. I actually added that later to try to fix the error.
> Chris
