Build of example fails with waf
Thu Aug 25 06:44:03 UTC 2016
On 25/08/2016 4:42 PM, Gene Smith wrote:
> On 08/25/2016 02:01 AM, Chris Johns wrote:
>> What happens if you remove --rtems-archs=arm from the configure command
>> line and just specify the BSP? The BSP name includes the arch.
> Same result. I actually added that later to try to fix the error.
I will take a look.
