Network problem for altcycv_devkit
Jianxun Yan
yanjx at jlab.org
Thu Aug 25 17:06:47 UTC 2016
Hi Adit,
I have the file
../rtems/bsps/4.12/arm-rtems4.12/altcycv_devkit/lib/include/bsp.h, but
doesn't have the macro, neither in the source file
rtems/rtems-gig/c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h.
Attach is the bsp.h file that I have.
Thanks for help.
Jay
On 08/25/2016 12:13 PM, Adit Sahasrabudhe wrote:
> You will find the macro in bsp.h. If you have already installed the altcycv_devkit BSP when building rtems, then you can find it under:
> <RTEMS_INSTALL>/arm-rtems4.xx/altcycv_devkit/lib/include/bsp.h
> Otherwise, in the source itself:
> <RTEMS_SRC>/c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h
> Adit
> On 8/25/16, 9:00 AM, "Jianxun Yan" <yanjx at jlab.org> wrote:
> Hi Adit,
> I couldn't find the macro RTEMS_BSP_NETWORK_DRIVER_ATTACH in my
> rtems/bsps directory. Did I do something wrong?
> Thank you for help.
> Jay Yan
> On 08/25/2016 11:19 AM, Adit Sahasrabudhe wrote:
> > Hi Jay,
> > Please see attached file for example. The driver attach function is defined by the macro RTEMS_BSP_NETWORK_DRIVER_ATTACH inside the BSP.
> > Adit
> > On 8/25/16, 7:32 AM, "users on behalf of Jianxun Yan" <users-bounces at rtems.org on behalf of yanjx at jlab.org> wrote:
> > Hi Sebastian,
> > How should I configure the network? Should I use both struct
> > rtems_bsdnet_config and rtems_bsdnet_ifconfig? Do you have any example
> > for altcycv_devkit network?
> > Thank you very much for your help.
> > Jay Yan
> > On 08/25/2016 10:18 AM, Sebastian Huber wrote:
> > > The network interface, USB and MMC drivers are part of the libbsd for this BSP.
> > > ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
> > >> Hi,
> > >> Since nobody answered my question, I have to post it again. Anyone can
> > >> help me?
> > >> Thanks,
> > >> Jay Yan
> > >> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
> > >>> Hi,
> > >>> Have anyone ever ran the network application for the Altera Cyclone V
> > >>> SoC board (BSP altcycv_devkit)? When I tried to configure the network
> > >>> interface, I couldn't find the attach network driver. What attach
> > >>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
> > >>> Thanks,
> > >>> Jay Yan
> > >>> _______________________________________________
> > >>> users mailing list
> > >>> users at rtems.org
> > >>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DQICAg&c=5VD0RTtNlTh3ycd41b3MUw&r=NQi5ZDATEqAUQ7YuH-e3LQ&m=oEFB8vuJ42tJ0BBhVxtD-j4x4Q2wnyatBXiG-d6MY7E&s=aQde8Wz_-uMJ4hPjMsoLHowSSxj2tcin5CP0na3cRSg&e=
> > >> users mailing list
> > >> users at rtems.org
> > users mailing list
> > users at rtems.org
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160825/5399fb44/attachment.bin>
