Build of example fails with waf
Fri Aug 26 00:39:56 UTC 2016
On 26/08/2016 06:10, Gene Smith wrote:
> I found the problem. The rtems.py submodule code defaults the rtems
> version to 4.11. So when I add the option --rtems-version=4.12 the
> configuration runs.
> This probably should be mentioned in the README.waf of examples-v2.
I think the solution is to move rtems_waf to a later version.
