Hello World example from example-v2 not working with QEMU
Fri Aug 26 14:31:27 UTC 2016
Please see the instructions in the examples-v2/README.waf or read
about how to use Application Makefiles
https://devel.rtems.org/wiki/Developer/Makefile to learn more about
how to compile and link an application with an installed build of
RTEMS.
Note that pc386 has a compile-time option to select the console
driver, see for an example:
https://devel.rtems.org/wiki/Developer/Simulators/QEMU#Usingthertems-testingModule
Gedare
On Fri, Aug 26, 2016 at 1:22 AM, Sambeet Panigrahi
<sambeet161616 at gmail.com> wrote:
> Hi
> I made the following changes to the commands in
> https://devel.rtems.org/wiki/Building/Grub for GRUB2
> set default="0"
> set timeout=10
> serial --unit=0 --speed=9600
> terminal serial
> menuentry "RTEMS Hello" {
>      set root='hd1,msdos1'
>      multiboot (hd1,msdos1)/examples/hello.exe --console=/dev/com1
> --printk=/dev/com1
> And my qemu.sh file looks like
> #!/bin/bash
> qemu-system-i386 -m 128 -boot b -hda rtems-boot.img -hdb fat:. -serial stdio
> -no-reboot
> But the problem stays the same.The examples-v2/hello/hello_world_c/test.c
> file still does not compile whereas the one from pc386 bsp testsuite
> compiles.That's why I think there's something wrong with my code.
> The source code is:
>  *  Classic API Hello World
> #include <rtems.h> //Contains the RTEMS datatypes
> #include <stdlib.h>//Standard C library
> #include <stdio.h>//Standard C input ouput library
> rtems_task Init(
>   rtems_task_argument ignored
>   printf( "\n\n*** MODIFIED HELLO WORLD TEST ***\n" );
>   printf( "Hello Sambeet!How are You?\n" );
>   printf( "*** END OF MODIFIED HELLO WORLD TEST ***\n" );
>   exit( 0 );
> /* configuration information */
> #include <bsp.h>
> /* NOTICE: the clock driver is explicitly disabled */
> #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_TASKS 1
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
> /* end of file */
> And I compile it using this command.I don't understand where I am going
> wrong as this produces the executable.
> /home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/bin/i386-rtems4.11-gcc
> --pipe
> -B/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/i386-rtems4.11/pc486/lib/
> -specs bsp_specs -qrtems   -Wall  -O2 -g    -mtune=i486      -o
> o-optimize/test.exe test.c
> users mailing list
> users at rtems.org
