RSB error downloading
Fri Aug 26 14:59:14 UTC 2016
On Fri, Aug 26, 2016 at 10:37 AM, Павел Трошин <troshinp at mail.ru> wrote:
> I'm trying to build toolset for rtems-4.9 but I have problem:
> ../source-builder/sb-set-builder --log=l-sparc.txt
> --prefix=$HOME/development/rtems/4.9 4.9/rtems-sparc
> RTEMS Source Builder - Set Builder, 4.12 (cac72a2aea71 modified)
> Build Set: 4.9/rtems-sparc
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
> building: expat-2.1.0-x86_64-linux-gnu-1
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
> config: tools/rtems-binutils-2.19.1-1.cfg
> package: sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1
> warning: binutils-2.19.1.tar.bz2: no hash found
> building: sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1
> reporting: tools/rtems-binutils-2.19.1-1.cfg ->
> sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1.txt
> sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1.xml
> config: tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
> package: sparc-rtems4.12-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
> download:
> https://git.rtems.org/rtems-tools/plain/tools/4.12/newlib/newlib-1.16.0-rtems4.9-20090324.diff
> -> patches/newlib-1.16.0-rtems4.9-20090324.diff
There seems to be a problem in how the rtems_version variable gets set
for the 4.9 tools. It looks like it should also affect 4.10...
I'm looking at it. I think the best long-term fix is to relocate the
4.9 configuration on to a separate 4.9 branch like we have done for
4.11.
> download:
> https://git.rtems.org/rtems-tools/plain/tools/4.12/newlib/newlib-1.16.0-rtems4.9-20090324.diff:
> error: HTTP Error 404: Not found
> error: downloading
> all paths have failed, giving up
> Build FAILED
>   See error report:
> rsb-report-sparc-rtems4.12-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1.txt
> error: downloading
> Build Set: Time 0:01:33.481326
> Build FAILED
> users mailing list
> users at rtems.org
