RSB error downloading
Fri Aug 26 15:03:10 UTC 2016
Please try the 4.9 branch instead. use "git fetch" to see it and then
"git checkout" to get on to it, since I have only just pushed it. I
tested that it gets at least past the point you report a failure, but
please let us know if it works for you, or if you have troubles.
Gedare
On Fri, Aug 26, 2016 at 10:59 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Aug 26, 2016 at 10:37 AM, Павел Трошин <troshinp at mail.ru> wrote:
>> I'm trying to build toolset for rtems-4.9 but I have problem:
>> ../source-builder/sb-set-builder --log=l-sparc.txt
>> --prefix=$HOME/development/rtems/4.9 4.9/rtems-sparc
>> RTEMS Source Builder - Set Builder, 4.12 (cac72a2aea71 modified)
>> Build Set: 4.9/rtems-sparc
>> config: devel/expat-2.1.0-1.cfg
>> package: expat-2.1.0-x86_64-linux-gnu-1
>> building: expat-2.1.0-x86_64-linux-gnu-1
>> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
>> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
>> config: tools/rtems-binutils-2.19.1-1.cfg
>> package: sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1
>> warning: binutils-2.19.1.tar.bz2: no hash found
>> building: sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1
>> reporting: tools/rtems-binutils-2.19.1-1.cfg ->
>> sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1.txt
>> sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1.xml
>> config: tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
>> package: sparc-rtems4.12-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
>> download:
>> https://git.rtems.org/rtems-tools/plain/tools/4.12/newlib/newlib-1.16.0-rtems4.9-20090324.diff
>> -> patches/newlib-1.16.0-rtems4.9-20090324.diff
> There seems to be a problem in how the rtems_version variable gets set
> for the 4.9 tools. It looks like it should also affect 4.10...
> I'm looking at it. I think the best long-term fix is to relocate the
> 4.9 configuration on to a separate 4.9 branch like we have done for
> 4.11.
>> download:
>> https://git.rtems.org/rtems-tools/plain/tools/4.12/newlib/newlib-1.16.0-rtems4.9-20090324.diff:
>> error: HTTP Error 404: Not found
>> error: downloading
>> all paths have failed, giving up
>> Build FAILED
>>   See error report:
>> rsb-report-sparc-rtems4.12-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1.txt
>> error: downloading
>> Build Set: Time 0:01:33.481326
>> Build FAILED
>> users mailing list
>> users at rtems.org
