Fwd: Re: Adding Eigen Library
Sambeet Panigrahi sambeet161616 at gmail.com
Mon Aug 29 01:44:25 UTC 2016
---------- Forwarded message ----------
From: "Sambeet Panigrahi" <sambeet161616 at gmail.com>
Date: Aug 29, 2016 6:53 AM
Subject: Re: Adding Eigen Library
To: "Chris Johns" <chrisj at rtems.org>
Cc:
How do I add the eigen header file to the makefile?Adding CXX flags like in
the code in the initial post is not working.
On Aug 29, 2016 6:49 AM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 29/08/2016 11:07, Sambeet Panigrahi wrote:
>> I am trying to test Eigen with RTEMS which is a very efficient library
>> in c++ for matrix computations.
> I can confirm Eigen works well with RTEMS on the ARM CortexA9 NEON.
> An RSB config to support it would be nice.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20160829/18f9027f/attachment-0001.html>
