RTEMS on Xilinx Zedboard
Chris Johns
chrisj at rtems.org
Wed Aug 31 03:08:42 UTC 2016
On 29/08/2016 05:00, Spencer Deevy wrote:
> Hello everyone, this is my first post here, so here goes.
Welcome to RTEMS and sorry about the time taken to reply.
> I've been trying to figure out how to configure RTEMS for the Zedboard
> development board for quite some time now, but with little luck..
I am testing and developing RTEMS on a MicroZed board so I hope I can help.
> I have looked through the board support packages, and I've tried
> building RTEMS for that board support package with the required cross
> compiler, but nothing seems to work.
A full build of all parts from source requires a few parts to come
together. I use a FreeBSD package for the compiler to build u-boot.
Everything else is from source.
> The two methods by which I can load an image onto the Zedboard are via
> the SD card, or by burning to the chip itself. I have more experience
> with burning images to the SD card, but either method would be fine.
I am using a 3rd option, u-boot on an SD card and booting over the
network to download RTEMS to run.
> If anyone has a step-by-step guide for building RTEMS with a BSP, or
> even the Zedboard itself, that would be great. If anyone has any advice
> on where to start on this, it would be much appreciated. Let me know
> your thoughts.
1. Host machine is FreeBSD 10.3-RELEASE-p3.
1.1 U-Boot needs an ARM compiler, using packages:
arm-none-eabi-binutils-2.25.1_1
arm-none-eabi-gcc-5.3.0
2. U-Boot
2.1 From git:
$ git clone git://git.denx.de/u-boot.git
2.2 Local patch (attached).
2.3 Build with:
$ gmake CROSS_COMPILE=arm-none-eabi- CONFIG_API=y
2.4 Copy spl/boot.bin to the SD card.
2.5 Copy u-boot.img to the SD card.
2.6 Create a suitable uEnv.txt to boot u-boot for your system.
(My SD crad reader is at home at the moment)
3. RTEMS
2.1 Build tools using the RSB for 4.12/rtems-arm.
2.2 Get RTEMS from git:
$ git clone git://git.rtems.org/rtems.git
Note: this patch is need:
https://lists.rtems.org/pipermail/devel/2016-August/015982.html
2.3 Bootstrap
2.4 Configure:
$ ../rtems/configure --target=arm-rtems4.12 \
--prefix=/opt/work/chris/rtems/kernel/4.12 \
--disable-networking \
--enable-rtemsbsp=xilinx_zynq_zedboard \
--enable-smp \
--enable-test
2.5 Build:
$ make -j 8
2.6 Convert the RTEMS executable so u-boot can load it. I attach a
script based on Pavel's posts. Please edit to your tools path:
$ rtems-zynq-mkimg \
./arm-rtems4.12/c/xilinx_zynq_zedboard/testsuites/samples/ticker/ticker.exe
2.7 Copy ticker.exe.img to the SD card or network download location.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160831/8e3832e5/attachment.bin>
#! /bin/sh
OBJCOPY_FOR_TARGET=/opt/work/rtems/4.12/bin/arm-rtems4.12-objcopy
OBJCOPY="$OBJCOPY_FOR_TARGET"
EXE_NAME=$1
START_ADDR=0x00104000
ENTRY_ADDR=0x00104000
${OBJCOPY} -R -S --strip-debug -O binary "$EXE_NAME" "$EXE_NAME.bin" || exit 1
cat "$EXE_NAME.bin" | gzip -9 >"$EXE_NAME.gz"
mkimage \
-A arm -O rtems -T kernel -a $START_ADDR -e $ENTRY_ADDR -n "RTEMS" \
-d "$EXE_NAME.gz" "$EXE_NAME.img"
