Re[2]: RSB error downloading
Павел Трошин
troshinp at mail.ru
Wed Aug 31 20:23:22 UTC 2016
Thanks, I switched to the 4.9 branch. Download tools works but download source rtems and failed.
../source-builder/sb-set-builder --log=l-sparc.txt --prefix=$HOME/development/rtems/4.9 4.9/rtems-sparc
RTEMS Source Builder - Set Builder, 4.12 (3266ec3e69c2)
Build Set: 4.9/rtems-sparc
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-binutils-2.19.1-1.cfg
package: sparc-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1
warning: binutils-2.19.1.tar.bz2: no hash found
building: sparc-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1
reporting: tools/rtems-binutils-2.19.1-1.cfg -> sparc-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1.txt
reporting: tools/rtems-binutils-2.19.1-1.cfg -> sparc-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1.xml
config: tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
package: sparc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
building: sparc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
reporting: tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg -> sparc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1.txt
reporting: tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg -> sparc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1.xml
config: tools/rtems-gdb-6.8-1.cfg
package: sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1
building: sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1
reporting: tools/rtems-gdb-6.8-1.cfg -> sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1.txt
reporting: tools/rtems-gdb-6.8-1.cfg -> sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1.xml
config: tools/rtems-kernel-4.9.6-1.cfg
package: sparc-rtems4.9-kernel-4.12 (3266ec3e69c2)-1
download: ftp://ftp.rtems.org/pub/rtems/releases/4.9/4.12 -> sources/rtems-4.12 (3266ec3e69c2).tar.bz2
download: ftp://ftp.rtems.org/pub/rtems/releases/4.9/4.12: error: <urlopen error ftp error: URLError("ftp error: error_perm('550 Failed to change directory.',)",)>
error: downloading (3266ec3e69c2).tar.bz2: all paths have failed, giving up
Build FAILED
See error report: rsb-report-sparc-rtems4.9-kernel-4.12 (3266ec3e69c2)-1.txt
Build Set: Time 0:13:24.213117
Build FAILED
>Пятница, 26 августа 2016, 18:03 +03:00 от Gedare Bloom <gedare at rtems.org>:
>Please try the 4.9 branch instead. use "git fetch" to see it and then
>"git checkout" to get on to it, since I have only just pushed it. I
>tested that it gets at least past the point you report a failure, but
>please let us know if it works for you, or if you have troubles.
>Gedare
>On Fri, Aug 26, 2016 at 10:59 AM, Gedare Bloom < gedare at rtems.org > wrote:
>> On Fri, Aug 26, 2016 at 10:37 AM, Павел Трошин < troshinp at mail.ru > wrote:
>>> I'm trying to build toolset for rtems-4.9 but I have problem:
>>> RTEMS Source Builder - Set Builder, 4.12 (cac72a2aea71 modified)
>>> package: sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1
>>> building: sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1
>>> sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1.txt
>>> sparc-rtems4.12-binutils-2.19.1-x86_64-linux-gnu-1.xml
>>> package: sparc-rtems4.12-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
>>> download:
>>> https://git.rtems.org/rtems-tools/plain/tools/4.12/newlib/newlib-1.16.0-rtems4.9-20090324.diff
>>> -> patches/newlib-1.16.0-rtems4.9-20090324.diff
>> There seems to be a problem in how the rtems_version variable gets set
>> for the 4.9 tools. It looks like it should also affect 4.10...
>> I'm looking at it. I think the best long-term fix is to relocate the
>> 4.9 configuration on to a separate 4.9 branch like we have done for
>> 4.11.
>>> download:
>>> https://git.rtems.org/rtems-tools/plain/tools/4.12/newlib/newlib-1.16.0-rtems4.9-20090324.diff :
>>> error: HTTP Error 404: Not found
>>> error: downloading
>>> Build FAILED
>>> See error report:
>>> rsb-report-sparc-rtems4.12-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1.txt
>>> error: downloading
>>> Build Set: Time 0:01:33.481326
>>> Build FAILED
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160831/b68dd2b4/attachment.html>
