Threading library used by rtems
Sambeet Panigrahi
sambeet161616 at gmail.com
Sat Aug 6 06:49:05 UTC 2016
I am also attaching the RTT manual component script I am trying to build
for creating an rtems executable:
The command on my host machine to compile is:
sambeet at Holmes ~/NewRockPort/x86/Build/rock/rtt $ sudo
/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/bin/i386-rtems4.11-g++
HelloWorld.cpp /usr/local/lib/liborocos-rtt-rtems.a
/usr/local/lib/orocos/rtems/types/librtt-typekit-rtems.a -I ./ -I
/usr/local/boost_1_54_0/include/ -L /usr/local/boost_1_54_0/lib/ -L
/lib/i386-linux-gnu/ -lpthread -static -DOROCOS_TARGET=rtems 2>&1 | tee
testout.txt
On Sat, Aug 6, 2016 at 10:41 AM, Sambeet Panigrahi <sambeet161616 at gmail.com>
wrote:
> Sir,
> I found that Orocos RTT works only for boost 1.54.Most other versions do
> not use a serialization::array_wrapper template rather than array.So I
> could finally manually compile an Orocos RTT component for gnu Linux.
> Adapting the component for RTEMS had a problem.I was using libpthread.so
> for gnu Linux ,which could not be used for rtems as it is not a static
> library.I could not find in thread library with .a extension i.e a static
> thread library in my local 4.11.0-rc3 build. So which thread library shall
> I use for building my RTT component for RTEMS?
> Regards
> Sambeet
URL: <http://lists.rtems.org/pipermail/users/attachments/20160806/8c4822bb/attachment-0002.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160806/8c4822bb/attachment-0002.bin>
