rtems-libbsd build problem for lpc24xx and lpc32xx.
Thomas Kim
thomas73.kim at gmail.com
Tue Aug 16 14:53:32 UTC 2016
Dear Kirspel,
Thank you very much for your help.
If you complete to test libbsd for lpc32xx, will you update this on current
rtems and libbsd ?
I want to get rtems and libbsd version which can support USB stack.
If there is any target which can support USB stack, please let me know that.
Best Regards,
Thomas Kim
2016-08-16 23:29 GMT+09:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
> That is correct. I almost have it working now. I plan to get back on it
> soon. I am working on a couple of things right now related to the
> lpc32xx. I am currently looking at getting VFP support for the LPC32xx.
> After that I will figure out why my rtems-libbsd port does not work in my
> application but works fine with the libbsd test suite.
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Opti Medical
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Tuesday, August 16, 2016 1:28 AM
> To: Thomas Kim <thomas73.kim at gmail.com>; Kirspel, Kevin <
> Cc: users at rtems.org
> Subject: Re: rtems-libbsd build problem for lpc24xx and lpc32xx.
> On 13/08/16 16:25, Thomas Kim wrote:
> > I found that lpc24xx or lpc32xx bsp can not support USB stack by
> > libbsd according to your advice.
> I am pretty sure that these two BSPs would work with some minor fixes.
> However, I don't have time for this at the moment.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160816/d2b68e53/attachment-0002.html>
