1kHz timer behavior on Cyclone V
Janet Schneider
janetsc at fb.com
Wed Dec 7 17:44:08 UTC 2016
Hello,
I am running a 1kHz timer test on the Altera Cyclone V dev board. I am trying to measure the average time period between the timer firing, and any variance on that latency.
I'm seeing an average of 1003 microseconds between the timer firing. About once a second, I see the maximum time between the timer firing go up to 2500-3000 microseconds.
I'm using rtems_clock_get_uptime_nanoseconds() to measure the time that the timer fires. I have CONFIGURE_MICROSECONDS_PER_TICK set to 500.
Has anyone else seen this (or something similar)? Any ideas what might be happening here?
Thanks,
Janet
URL: <http://lists.rtems.org/pipermail/users/attachments/20161207/45515398/attachment.html>
