How to generate meaningfull stacktraces with RTEMS on the Leon3
Jiri Gaisler
jiri at gaisler.se
Thu Dec 8 07:39:45 UTC 2016
Remember that on SPARC (leon3), parts of the stack will be cached in the
register file windows. Printing the backtrace by following the
stack/frame pointers will then not work unless all windows are first
flushed to memory. This is done automatically on high-level O/S (Linux &
Solaris), but not on embedded systems like RTEMS.
Jiri.
On 07/12/16 13:30, Matthew J Fletcher wrote:
> Hi,
> The gcc builtin functions (and libunwind) and only work if the stack
> frame information is not optimised away, this is controlled by gcc
> compiler flags,
> see; https://gcc.gnu.org/onlinedocs/gcc/Optimize-Options.html -fomit-frame-pointer
> Without that you have to do your own unwinding, for example on x86 you
> could do the following, but its pretty crude. Linux/FreeBSD do much
> more fancy unwinders, it depends on what you want.
> #define get_ebp() \
> ({ unsigned long __value; \
> asm volatile (" mov %%ebp,%0": "=a"(__value)); \
> __value; })
> void error_dump_callstack(int fd)
> unsigned longebp=0,arg0,arg4,arg8,arg12,arg16;
> int i;
> arg0 = get_ebp(); // base pointer, start of current stack frame
> assert_out(fd,"\r\nCall Stack Information:\r\n\r\n");
> for (i=0; i<15; i++)
> // attempt get backtrace (with arguments) from stored EPB
> arg0 = *(unsigned long*)(arg0);
> if (arg0 == 0)
> break;
> // print stackframe back past inturrupt
> arg4 = *(unsigned long*)(arg0+4);
> arg8 = *(unsigned long*)(arg0+8);
> arg12 = *(unsigned long*)(arg0+12);
> arg16 = *(unsigned long*)(arg0+16);
> sprintf(assertbuffer,"ebp: %p\r\nframe%d: %p\r\narg1:
> %p\r\narg2: %p\r\narg3: %p\r\n",arg0,i,arg4,arg8,arg12,arg16);
> assert_out(fd,assertbuffer);
> assert_out(fd,"use 'addr2line -C -e abc.elf -f address' to get symbol
> names\r\n");
> On 6 December 2016 at 22:36, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 06/12/2016 01:46, Jan Sommer wrote:
> Is there a common way how to create stacktraces in RTEMS?
> Not that I know of.
> I tried to use the _Unwind_Backtrace_-function from gcc, but
> so far it
> only returns _URC_END_OF_STACK if I call it from a leaf function
> (haven't tried a trap handler yet).
> The end of stack code means the unwinder could not find any data
> about the frames in the stack. The default DWARF unwinder, which
> SPARC uses, searches for a valid Frame Description Entry (FDE) and
> if not found reports the end of stack code. If an FDE is found the
> Common Information Entry (CIE) is extracted from that data and the
> frame info decoded.
> C++ uses the same process for exceptions. A .eh_frame plus some
> other sections are created and the frames effected by the
> exceptions added to these sections. These sections are registered
> at start up. For a DWARF unwinder, which includes the SPARC, the
> DWARF standard is used for the format of these sections.
> I am not sure if that is the way to go.
> I am not 100% sure myself. I think you would need to include some
> level of DWARF related information in the executable to do this.
> This information would need to be registered with the DWARF
> unwinder code via something like 'void __register_frame (void
> *begin)'.
> I would also take a look at FreeBSD and see how they implement the
> unwinder. I do not know if the FreeBSD kernel has one.
> Are there any recommendations or examples for this topic?
> The DWARF standard website is the best source of info:
> http://dwarfstd.org/
> Chris
> users mailing list
> users at rtems.org <mailto:users at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/users>
> regards
> Matthew J Fletcher
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161208/09b327b9/attachment.html>
