working with rtems
yaron o
jaron0123 at gmail.com
Sun Dec 18 09:17:35 UTC 2016
Hello There,
I have two of questions that i hope you could help me with.
First , i'm using a serial communication that is UART , i get a massage in
binary (from RX) and need to parse it , i'm using a string to save the
binary massage and with pointers save relevant fields in massage in
correct variables, the problem is when i need to parse to double , every
time i'm taring to put the binary massage part directly in to double
variables i'm getting an error that say "IU in error mode (tt = 0X07 mem
address not aligned), so i tries to split the binary to two long variables
and concat between them with bit-wise operators still no successful and
same error as above . any idea to anyone?
Second question : i want to put some function and add new interrupts when
the OS is first initialize , in witch file i finding the OS initialization
process?
im using rtems 4.10 , leon 3 processor ,
hope everything is clear thank to helpers
Yaron
URL: <http://lists.rtems.org/pipermail/users/attachments/20161218/986cdd27/attachment.html>
