Can't find the ticker executable.
Tanu Hari Dixit tokencolour at gmail.com
Wed Dec 28 03:07:22 UTC 2016
Hey Denis,
Which BSP did you try? If it was sis, it has been removed from master
recently. You should try with erc32 with 4.12 toolchain. I had a
similar problem few days back and the devs pointed this out to me.
Regards,
Tanu Hari Dixit
On Wed, Dec 28, 2016 at 3:27 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> Hello, I've started to investigate RTEMS. I installed a toolchain, and after
> this I executed an installation script. I followed these instructions:
> https://devel.rtems.org/wiki/Developer/Tools/RSB
> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start
> And the problem is, that I can't find the ticker executable.  There were no
> errors during installation. Also, first time I tried to build 4.12 toolchain
> (couldn't find the ticker, removed toolchain), after that downloaded 4.11
> toolchain and build it, again couldn't find the ticker executable.
> Regards, Denis Obrezkov
> users mailing list
> users at rtems.org
