1kHz timer behavior on Cyclone V
Janet Schneider
janetsc at fb.com
Thu Dec 8 20:47:41 UTC 2016
I've pasted my program below.
I don't think I'm having issues printing the output, since I only print once a second. But I'm seeing the max period between the timer firing go as high as 3000 microseconds.
Thanks,
Janet
#include <bsp.h>
#include "../../testmacros.h"
#include <assert.h>
#include <limits.h>
// Timer statistics
volatile uint64_t g_prevUpTimeUsec;
volatile uint64_t g_totalProcessingPeriodUsec;
volatile uint64_t g_maxProcessingDeltaUsec;
volatile uint64_t g_minProcessingDeltaUsec;
volatile uint32_t g_numTimerIntervals;
static const uint32_t kNumTimerIntervals=1000;
rtems_id main_task;
rtems_timer_service_routine test_timer(
rtems_id timer,
void *arg
// restart the timer
(void)rtems_timer_reset(timer);
uint64_t currUpTimeUsec;
uint64_t processingDeltaUsec;
currUpTimeUsec = rtems_clock_get_uptime_nanoseconds() / 1000;
assert (currUpTimeUsec > g_prevUpTimeUsec);
processingDeltaUsec = currUpTimeUsec - g_prevUpTimeUsec;
g_totalProcessingPeriodUsec += processingDeltaUsec;
assert(g_totalProcessingPeriodUsec > 0);
g_numTimerIntervals++;
g_prevUpTimeUsec = currUpTimeUsec;
if (processingDeltaUsec > g_maxProcessingDeltaUsec) {
g_maxProcessingDeltaUsec = processingDeltaUsec;
if (processingDeltaUsec < g_minProcessingDeltaUsec) {
g_minProcessingDeltaUsec = processingDeltaUsec;
if (g_numTimerIntervals == kNumTimerIntervals) {
uint64_t avgProcessingPeriodUsec;
avgProcessingPeriodUsec = (g_totalProcessingPeriodUsec /
g_numTimerIntervals);
printk("total %d\n",(int)g_totalProcessingPeriodUsec);
printk("avg %d\n",(int)avgProcessingPeriodUsec);
printk("min %d\n",(int)g_minProcessingDeltaUsec);
printk("max %d\n",(int)g_maxProcessingDeltaUsec);
g_totalProcessingPeriodUsec = 0;
g_maxProcessingDeltaUsec = 0;
g_minProcessingDeltaUsec = 0xffffffffffffffff;
g_numTimerIntervals = 0;
rtems_task Init(
rtems_task_argument argument
rtems_status_code status;
rtems_id timer;
puts( "\n\n*** 1kHz TIMER TEST START ***" );
main_task = rtems_task_self();
status = rtems_timer_create( 1, &timer );
assert( status == RTEMS_SUCCESSFUL );
// Set up timer
rtems_interval timer_ticks;
timer_ticks = (rtems_clock_get_ticks_per_second() / 1000);
assert (timer_ticks == 2); // 500 usec per "tick"
// Set timer globals
g_prevUpTimeUsec = rtems_clock_get_uptime_nanoseconds() / 1000;
assert (g_prevUpTimeUsec > 0);
status = rtems_timer_fire_after(timer, timer_ticks, test_timer, NULL);
int i;
for(i = 0; i < 60; i++) { // Run for 2 min...
rtems_task_wake_after(timer_ticks * 1000);
rtems_timer_cancel(timer);
puts("*** 1kHz TIMER TEST END ***\n\n");
exit( 0 );
/* configuration information */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MICROSECONDS_PER_TICK 500
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_MAXIMUM_TIMERS 1
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Wednesday, December 7, 2016 10:52:59 PM
To: RTEMS
Cc: Janet Schneider
Subject: Re: 1kHz timer behavior on Cyclone V
Hello Janet,
could you send your test program to the list? How do you report the
timestamps? Via a serial line?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20161208/bd7d7387/attachment-0002.html>
